PAW |
Posted - 08 Oct 2012 : 21:26:49 When the Maestro II is changed, which only takes about an hour, the kite: - has like no oversteering - is slower - is way more precise - has a bigger windrange in both upper and lower - handles bumpy winds better - is more stable in backflip and fade - is more easy to trick - has more overall control - does way more tricks - makes more noise ...all this is, with the materials of the original kite, after the modifications ! If you want to use better materials, then use the upgrades step by step, it gets better & better...
----------------------------------------------------- Greetings from Germany, Peter :-) My kite vids: http://www.youtube.com/user/PAW211271?gl=DE&hl=de |
